Orbi WiFi 7 RBE973
Reply
Automatic switching from 2.4 to 5.0
djsteele1
Why does my connection on this cable modem wireless router keep dropping. I either connects to Guest or drops on 2.4g or 5.0g. Is there a software or firmware updte to solve this issue.
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 4
JamesGL
Master
Re: Automatic switching from 2.4 to 5.0
Hi djsteele1,
What is the model number of your router?
You may check http://netgear.com/support/ for firmware updates.
Message 2 of 4
djsteele1
I think this is my Model Number at least that is what is on the backside. How do you know what version it is exactly? I know it is a AC1900 Model: C7000 - but there are no other indications on the back of the router. Thanks
Model: R6800|Nighthawk AC1900 Smart WiFi Router
Message 3 of 4
DarrenM
Sr. NETGEAR Moderator
Hello djsteele1
Have you tried to adjust your wireless channels in the routers wireless settings.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2446 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
