- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3000 N300 modem/router won't allow 2 wired lan connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a wired lan connection for a security camera DVR on my C3000 cable modem/router. When I tired to add a Liftmaster internet gateway garage door control (also wired) to the second ethernet port, the router would not recognize it. So I disconnected the DVR and the gateway worked fine. When I reconnected the DVR the gateway quit working. Either system works normally alone but the router will not recognize both systems. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3000 N300 modem/router won't allow 2 wired lan connections
Hello Pete51
Could be some type of overlapping happening have you reserved IP address for each system and done all the proper port forwarding?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
That was my guess too but the router wouldn't save the changes. I called netgear tech support and after nearly three hours of trying they told me to just buy a new router. I did that and the new Netgear router was defective. I've returned it and will never buy another Netgear product. The products don't work and their support is worthless
- Mark as New
- Bookmark
- Subscribe
- Permalink
are you with SPECTRUM (charter/TimeWarner or BrightHouse) isp?
