Orbi WiFi 7 RBE973
Reply
C3700 Repeatedly Assigning IP
C37
I've noticed this recently. I have another post up with some questions and other weird things, but now I've noticed this.
The device is my phone. I have an Echo Show that runs right beside my phone at night playing sleep sounds. I've started to notice it go out almost every night. Sometimes it's just for a few seconds. This is consistent with times that I've noticed my phone or tv would just randomly drop connection for a few seconds then reconnect. Other times it will stay disconnected for longer. Edit: I've resorted to playing sleep sounds from my phone to the Show with Bluetooth when this happens. I wonder if interference could be an issue, though I've never had the issue before, and I've used Bluetooth often.
This morning I noticed the IP assignment had gotten way worse. I've recently factory reset. I don't think it's an Internet issue. Any ideas? Also, if this is the router just dying, my other question is would it be okay to put it in bridge and add another router, or would these signs point to issues with modern functionality?
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 5
Guru
Re: C3700 Repeatedly Assigning IP
Have you tried setting a IP address reservation ON the modem for these devices?
Message 2 of 5
C37
No, but I just set one for my phone to see if it helps.
Message 3 of 5
Guru
Let us know how it goes.
Message 4 of 5
C37
I didn't notice an interruption last night. However, they returned this evening. Just within the past hour or two I've noticed my phone lose connection and reconnect about 6 times. I have since reserved an address for every device on my network, only about 7, and it doesn't seem to have had any sort of positive effect.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 882 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
