Orbi WiFi 7 RBE973
Reply
C6250 Losing Connection
J_Ellis
My router wifi connection isn't consistent. When I power cycle it, it'll work for a while then it'll drop to the point where nothing will load. It goes back and forth between working and not working. The Netgear genie says the firmware is up to date, but there's nowhere for me to manually update it if I wanted to. Any suggestions?
Model: C6250|AC1600 WiFi Cable Modem Router
Message 1 of 4
Accepted Solutions
Guru
Re: C6250 Losing Connection
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Message 2 of 4
All Replies
Guru
Message 2 of 4
J_Ellis
That helped! I appreciate it.
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2308 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
