- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6250 Wifi Dropping With Strong Signals
- Mark as New
- Bookmark
- Subscribe
- Permalink
My wifi connection has been dropping every minute or so. I currently have the C6250 cable modem router. My firmware is V1.02.01. My provider is comcast. The router is directly connected to the coax with no splitters. The items that are hard wired through ethernet don't have any connection drops. The devices that are using wifi are typically located about 5 feet from the router. Comcast claims there isn't anything wrong on their end. Any help would be greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6250 Wifi Dropping With Strong Signals
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply! I'm on channel 1 for 2.4 Ghz and 36 for 5 Ghz. Unfortunately I live in a large building so have quite a few wifi neighbors (20+). I have done a factory reset but it didn't make a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try channels 6 or 11.
Do you have any power output adjustments under Under Advanced Tab/Advanced Settings/Wireless Settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for the late reply. I did switch to channel 6 but it didn't make a difference. I don't have anything listed for power output adjustments in any of my settings.
