- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300 5Ghz Not Working and no firmwear updates available
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have noticed that the 5Ghz band on my modem/router combo does not work anymore.
I have only had this unit for 3 months and I have tried everything from unplugging the device to contacting my ISP and even searching for firmwear updates online. Nothing has come through to solve this problem.
My iPad also no longer connects to the internet, although it recognizes and "appears" to connect to the correct wifi network.
HELP!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300 5Ghz Not Working and no firmwear updates available
Hello OkW2030
You could test to see if the ISP is blocking the wireless connection or if its a hardware issue. If you factory reset the unit but do not plug it into the cable line then see if the 5ghz band shows up and see if you can connect if so try plugging the cable line back into the modem and see if it stops working if so the modem is coded to block it by the ISP if not then could be a hardware issue and you will have to contact support.
DarrenM
