Reply
C6300 AC1750 and xfinity 400MBps download plan
netmask001
does this router support comcast 400Mbps download plan? The specs says up to 680Mbps download? but comcast is saying it only downloads at 384mbps
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 4
Guru
Re: C6300 AC1750 and xfinity 400MBps download plan
The ISP is the one who rates it for their service/setup.
Its capable of faster speed depending on how the isp provisions their setup but comcast is correct in their speed rating for their service.
I'd encourage you to look at docsis 3.1 devices as we're seeing isp's lowering the speeds at which point they require 3.1.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
netmask001
so can i use the c6300 for a 400mbps download plan on xfinity?
Message 3 of 4
Guru
Can you use it on a 400mbps plan? sure.
Will it get 400mbps? not if xfinity doesn't support 400mbps on that device.
You could use it on a gigabit plan but it won't hit those speeds. its all wha the ISP provisions it for and supports.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 282 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
