- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300 - Cannot perform firmware upgrade - GUI missing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I am trying to do a firmware upgrade on my C6300 router. I have tried going to this website for instructions:
https://kb.netgear.com/000053268/R6300v2-Firmware-Version-1-0-4-20
The site suggests that I go to administration tab and select the firmware button, but the problem is on my GUI I do not have this option. I have also tried downloading the Netgear Genie application and this also does not work.
I have seen on some forums that the ISP needs to perform the firmware upgrade, but the issue is, this is my personal router.
Does anyone know a simple workaround to this issue? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300 - Cannot perform firmware upgrade - GUI missing
Generally speaking, you can't.
https://community.netgear.com/t5/x/x/m-p/1490471
Doesn't matter. You still can't. If you search around, then you
should be able to find similar responses from actual Netgear agents.
Define "simple". Contact your ISP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. So I purchased a router from bestbuy and I cannot perform upgrades because only a ISP, that shouldnt have access to my personal router, is allowed to...great product Netgear.
With that being said, I am trying to connect this cable router directly to the coaxial feed from my Spectrum internet. I was on the phone for 3 hours yesterday with tech support and the signal could not sync...it would lock in but would not sync, therefore I could not get internet connection. The tech said that I should try to perform a firmware upgrade, since Spectrum says it should be at V2.01.22, when my current firmware is at V2.01.18 (src: https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mod...).
Should I keep troubleshooting with Spectrum?
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] only a ISP, that shouldnt have access to my personal router, is
What if it's not Netgear's decision?
https://community.netgear.com/t5/x/x/m-p/1354161#M9935
Have you another option?
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
