Orbi WiFi 7 RBE973
Reply
C6300 Log under Genie Administrative Advanced Entry
GVR61
Initiate
The entry below is on my Log under Advanced>Administrative several times. What  does it mean? Also this entry does not contain a valid IP address that I can see. What do the string of characters mean or where does it indicate the attack came from? Other DOS entries have valid IP addresses (France, Czechoslovakia, etc). Also, how concerned should I be that I can't update my firmware because NETGEAR says the ISP has to do it and the ISP tells me to contact NETGEAR and NETGEAR is no help.
[DoS attack] ICMP Flood from fe80:0000:0000:0000:027e:95ff:fe40:6419
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 4
antinode
Guru
Re: C6300 Log under Genie Administrative Advanced Entry
> [...] this entry does not contain a valid IP address that I can see.
   Not "see", "recognize".  "fe80:0000:0000:0000:027e:95ff:fe40:6419" is
an IPv6 address.
      https://en.wikipedia.org/wiki/IP_address
Message 2 of 4
GVR61
Initiate
Thank you for your response.
Does this mean I need to turn on my IPv6 Firewall Protection under Advanced>Advanced Setup>IPv6?
Message 3 of 4
jimyjames
FE80 is an ipv6 link local address. Those are not routable outside of their own network. That means it is coming from inside your network and is already inside your routers firewall. So setting up the routers ipv6 firewall would have no effect. It is possible that another device in your network has been compromised and is being used to stage an attack.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1087 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
