- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300v2 firmware out of date
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300v2 firmware out of date
@MATiX wrote:
I am on Netgear C6300v2 firmware version 1.02.09 ; which is not the most up to date but I cannot change that. I still DL speed at 600Mbps.
You cannot change the firmware on a cable modem. That is in the hands of the ISPs. They make the rules.
Try fixing the main problem.
But sometimes my devices will not load websites and say that I have no connectivity.
You will need to provide more information before anyone can begin to diagnose what might be going on there. The ability to use the Nighthawk app wouldn't be much help there. The apps are dumbed down versions of the browser graphical user interface (GUI).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaelkenward has answered the firmware issue.
Do you have a copy of the cable connections page and the event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
