- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000-AC1900 intermittent internet - drops for 5-10 minutes every 2-3 hours
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000-AC1900 intermittent internet - drops for 5-10 minutes every 2-3 hours
Do wired connections also not connect when this happens?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the response.
I use channel 6 for 2.5 since 11 seems to be quite busy -> 6+ which includes two of my extendors (EX2700 and Rockspace 1200Mbps) as well. There are quite a few wifi networks in the neighbourhood and the channel assignments looks very different each time I check.
I have channel 60 for 5, which seems to be DFS. I guess this is fine?
I presume the wired connections have the same problem because whenever there is a wifi glitch I get the message that the Samsung smarthings hub, which is wired to the modem-roter, is disconnected too.
By the way, yesterday night, the whole network went down for a while, and then I realized that I couldnt even find my 2.5 and 5G SSIDs. It looks like the C7000 unit somehow got reset and was transmitting the default NETGEAR SSIDs, and I had to set up the whole thing from the scratch. This has happened once before as well, a few months ago. I am not sure if this is OK or if i should be concerned (like a hack). 😞
Thank you,
Vibin
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Stanzzz wrote:Thanks for the response.
Can you disable the extenders for a while and lets let if we can stablize the modem alone.
Is there a power output setting under Advanced Tab/Advanced Settings/Wireless Settings by chance>?
Please channge this channel to 36 thru 48 or 149 thru 165.
Possible the modem and WAN are going down. I know that some modems will reboot if the WAN signal goes down.
Not this isn't a hack, more like bad modem operation. The modem should not be resetting to factory on it's own.
Something to contact NG support about.
