Orbi WiFi 7 RBE973
Reply
C7000 + HP Officejet 8035 DoS attack
Briano42
Follower
Hi
I have a HP Officejet 8035 on the 5G channel of my C 7000. The other night I had a DoS attack from the printer’s IP address. This caused about 20 minutes of no service on the 5G, although the 2.4 worked.
I searched for this issue and saw that there was a flurry of posts in 2016 about a C3700 and an HP 6830 that seemed to be the same problem as mine. But I don’t see any recent posts about my affected models
Anyone know if this is a long running problem, or if it’s come back with my combination of models?
Thanks.
https://community.netgear.com/t5/Cable-Modems-Routers/HP-OfficeJet-printer-seems-to-cause-DoS-messag...
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: C7000 + HP Officejet 8035 DoS attack
Try the option linked. Be sure the printers FW is updated.
If the printer supports a LAN connection, switch to this on the printer.
Contact the printers mfr for additional help and information.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 337 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
