- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000 bridged with r7800 problems renewing isp dhcp
- Mark as New
- Bookmark
- Subscribe
- Permalink
Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=a0:04:60:5f:2c:c8;CMTS-MAC=00:01:5c:6b:44:4b;CM-QOS=1.1;CM-VER=3.0;
2020-4-12, 23:03:06 Warning (5) Dynamic Range Window violation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000 bridged with r7800 problems renewing isp dhcp
Please take a screen snip of your cable connections page and your logs.
get all the info off the connections page as this shows the upstream/downstream connection to your isp.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
and the cable connection page?
should look similar to the one i attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're downstream power levels are a little on the high side and your upstream is on the low side. upstream you usually want 35dbmv and you're right there but if the signal drops, you'd be low. And you've a few errors in your signal but nothing crazy.
Here's where I'd start.
If there's any amplifiers, attenuators, splitters in the coax line, remove them. Use it for a while and see how it runs. And then run this same screen shot again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it causing issues? i re-read back through and it didn't state exactly what it was causing.
If you're having drops, I'd have the isp check the line
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any resolution?
I am having the same problem with WOW
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
@dincoglu wrote:Any resolution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow replaced the line from the pole to the box ( box to the modem was already new) and the problem disappeared.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
