Orbi WiFi 7 RBE973
Reply
C7000 poor wifi, caused by traffic?
Bobby91
So I have a C7000 modem/router combo though Comcast. I'm paying for speeds up to 200mbs. Right now I get 50 IF I'm lucky. Comcast says that it is caused by high traffic and that i should go back to there brand modem (LOL over a Netgear Nighthawk?) I've also called Netgear and they walked me through on how to get the most out of my modem. I have changed my channel, downloaded the latest firmware, I'm lost at this point. Everyone says to just plug it in through LAN to get higher speeds but it's not like I can keep my laptop stationed next to the modem or have a massive cable running through the house. Any ideas?
Message 1 of 3
Bobby91
Re: C7000 poor wifi, caused by traffic?
Message 2 of 3
200 Mbps over wifi is a big ask.
Spend some time on Google and you will find that there are limits to wifi speeds.
What speed should I expect to see on my WiFi compared to my bandwidth - [Solved] - Wireless Networki...
What is the actual real-life speed of wireless networks ? :: SG FAQ
Everyone says to just plug it in through LAN to get higher speeds ...
They are right.
You may get better speeds if you use powerline adapters to create a wired network.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3170 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
