Orbi WiFi 7 RBE973
Reply
C7000V2 Connectivity Issues
Chasem715
Tutor
Hi,
I have a c7000v2 router / modem that goes offline everyday and I have to unplug and plug the router back in. When this happens all devices loose internet connection and the lights on the router are all solid green. I have had a new line ran from xfinity but still having the same issues
Message 1 of 19
Guru
Re: C7000V2 Connectivity Issues
Do you have a screen snip of the cable connections page and the event logs from the modem?
Message 2 of 19
Chasem715
Tutor
Message 3 of 19
Guru
and the cable connections page?
Message 4 of 19
Chasem715
Tutor
Screen Shot 2021-01-21 at 11.04.20 AM.pngScreen Shot 2021-01-21 at 11.04.09 AM.png
Message 5 of 19
Guru
photos can take several days to be approved by moderators. You can click on "choose file" and attach them 1 at a time and we can view them that way. otherwise we don't get a notice when they do get approved so don't check back on the posting.
Message 6 of 19
Chasem715
Tutor
Thanks
Message 7 of 19
Chasem715
Tutor
Message 8 of 19
Guru
Your power levels are just slightly out of spec. Not bad though.
And your logs are based off when it was rebooted so its not showing anything.
Next time the internet drops before you reboot it, log in and get the same logs and cable connections page info.
Message 9 of 19
Chasem715
Tutor
Sounds great, thanks for your help this far, I factory reset lastnight so hopefully that solved the issue
Message 10 of 19
Chasem715
Tutor
Just happened again
Message 11 of 19
Chasem715
Tutor
Message 12 of 19
Guru
sorry, thats router logs and not modem logs.
And you only got about half of the cable connections page.
Message 13 of 19
Chasem715
Tutor
Message 14 of 19
Chasem715
Tutor
Message 15 of 19
Chasem715
Tutor
Message 16 of 19
Guru
are those logs after you rebooted it? Usually the time only resets after a reboot. and rebooting resets the logs.
we need to see the logs while its having the issue.
Message 17 of 19
Chasem715
Tutor
No, I have not touched it. Seems to be rebooting itself now
Message 18 of 19
Guru
Well you're caught in a catch22. it could be the line. it could be the modem.
If its the line, the isp would nee to check it.
if its the modem, you'd need to replace it.
cheapest ways to check?
1. connect back an old modem and use it and see if it works.
2. rent a modem from the isp to see if everything thing works. If it doesn't, then they can't blame the euipment and would need to fix the line. I've rented one for a month before to prove it was a modem issue.
Message 19 of 19
Discussion stats
  • 18 replies
  • 1703 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
