- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000v2 can't connect to router IP, redirected to www.netgear.com/home/services/routerlogincom/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have had this cable modem/router for two years. Until recently always used the IP address in a browser (on a PC connected to router ethernet port) to login as admin and manage home network. Now every time it redirects to https://www.netgear.com/home/services/routerlogincom/ and provides a guided assistance page. Tried it, none of the suggestions work.
Wifi is up, my laptop and tablet can access, but for some reason my Android phone cannot connect since 2 days ago.
I don't understand why this redirection takes place
Also tried the Nighthawk app with the correct admin password and it fails to login.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 can't connect to router IP, redirected to www.netgear.com/home/services/routerlogincom/
What IP address are you using in a web browser? 192.168.#.1? or 192.168.100.1?
Might try a factory reset and setup from scratch on the modem...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for responding.
router's IP is 192.168.#.1
I don't know firmware since I can't login.
yes, factory reset came to mind.
I'd still like to know why this redirect happens (if that's the right term) and how to prevent it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it's the screen i'm thinking of, at the very bottom of this first setup page, do you see something referring to a link that meantions using an alternative way to set up the router? Should be something at the very bottom fo the page in text say to select here if you don't have the NH app...
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're allowed to reveal what you actually used.
Did you try "192.168.100.1"?
At a distance, it's tough to guess exactly why. If your browser (or
lame Netgear firmware, or something else) does a reverse
(number-to-name) look-up for "192.168.0.1", and then uses the resulting
name, it can defeat your attempt to bypass DNS problems by using the IP
address.
User | Count |
15 | |
8 | |
8 | |
6 | |
2 |
