- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000v2 port forwarding issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am trying to open some ports that I could work on servers but it does not works properly even I saw lots of solutions here and tried bunch of different ways but still no luck and here is my situation.
It seems like it does not block entire ports if I enable the readyshare which they are using 21 for FTP and 443 for HTTPS, its clearly I could check those are open and close depends enabled or disabled. but the problem is when I try to open the ports by the menu on Advanced Setup -> Port Forwarding / Port Triggering to add some ports it shows still closed like below photo.
Am I missing something? I already checked with my ISP that does not block the specific port I want to open too. I am not sure what else I can try to open them?
appreciated your help!
edited: image uploading did not work so I added the link of photos
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 port forwarding issue
> does not works properly [...]
"servers"? Which kind of "does not works properly" is this?
"does not" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] Am I missing something? [...]
Probably, but I can't see what you did.
Presumably, you have some kind of system at "192.168.0.24", which
might be running some servers, which might be listening at ports like
80, 7777, and 27015. Those port-forwarding rules look ok, if that
system really is at that LAN IP address. How, exactly, are you trying
to communicate with those servers? From where?
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
There are some questions and tests there which might be helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Thanks for quick answer but sorry to late reply back.
So, I am trying to open the Steam games dedicate servers which most games using port 27015 I believe
I am curious what parts I need to post here to get help from you?
I followed the way to port-forward the what you suggested page also but that's basically what I did.
I am not sure what additionally I have to deal with.
Thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
check your firewall settings too
- Mark as New
- Bookmark
- Subscribe
- Permalink
"parts"? You could try answering the questions. Look for "?".
"basically" and "exactly" are spelled differently for a reason.
Still true. Look for "?".
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am sorry about my lack of English which its not my first language. I was meaning by that.... what do you need to see on my setting so you can check what did I wrong or did not yet? I can reply with screenshot them.
Also, I checked the firewall too.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> I am sorry about my lack of English [...]
Your English is good.
> [...] what do you need to see on my setting [...]
The settings in your pictures look good.
What I'd like to see now are answers to the questions here and in:
For example, I don't need to see your (whole) public IP address, but:
> Does the IP address of the WAN/Internet interface of your router
> match what you're using as your public IP address from the outside
> world? ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
Also:
> Can you access the server from a system on your LAN using the
> server's LAN IP address? [...]
Again, look for "?".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I checked the Internal IP Address on Advanced -> Advanced setup -> port Forwarding's Internal IP address is 192.168.0.24 which I can see my current IPv4 on cmd is also 192.168.0.24
And I can't access through the LAN either somehow. I thought I should able to connect with my internal IP but it shows on server list though.
Also, here is what current WAN setup page looks like,
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address should
be your router's WAN/Internet IP address. "192.168.0.24" should be the
IP address of your (Windows) server system. They can't be the same.
> though.
Regarding "can't", see "not a useful problem description", above. I
don't know what "my internal IP [address]" means to you. Do _you_,
personally, have an IP address, or is that the IP address of some
network interface on some device? Which interface on which device?
What is that address?
> Also, here is what current WAN setup page looks like, [...]
Nothing useful there.
