- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7100V - Can't connect to Skype
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just switched to Comcast. I bought the Netgear C7100V Modem/Router instead of renting from Comcast. Everything seems to work fine, except I can't connect to Skype. When I open Skype (program) and try to log in, message shows "Skype can't connect". My firewall settings are fine. I tried port forwarding the ports listed at https://support.skype.com/en/faq/FA148/which-ports-need-to-be-open-to-use-skype-for-windows-desktop. When I enter the ports for TCP/UDP, the router gives me an error saying "the specified ports are being used by other configurations. Please check your configurations of USB ReadyShare, Remote Management, Port Forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet Connection type".
I'm running Win7. Had no issue using Skype before switching to Comcast & the new router.
Has anyone encountered this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7100V - Can't connect to Skype
can you please give a screenshot of the error?
did you disable any uPnP settings on C7100V?
Is it possible for you to capture traffic on your using wireshark?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have installed Wireshark, but I'm not familiar with it and don't know how to use it.
I was having trouble uploading photos to Netgear, so I posted a screen shot of UPnP settings and the Port Forwarding Error -> https://photos.app.goo.gl/7PTJ9a1IOad1cvP13
Thanks for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I captured a Wireshark log, but don't see any way to upload to Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks. you can PM me with the attachement.
also, can you please post your SKYPE error screenshot as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I uploaded a screenshot of Sype log in to https://photos.app.goo.gl/7PTJ9a1IOad1cvP13.
I was going to PM you but I still didn't see a why to attach any file that is not a picture.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks like my trouble was casued by an earlier version of Skype. I updated to the latest version Skype and was able to connect.
Thank you for your support!
