- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7100V Lan Set Up Change - WebServer does not work on 10.0.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a large home network with some static IPs in use. I use 10.0.0.1/24 and would like the C7100V act as a DHCP server.
I would like to chnage the Lan TCP/IP set up from the default 192.168.0.1 to 10.0.0.1. I'm able to do this, and my end points do receive an IP in the 10.0.0 space; however, once I do this I can no longer access the web server running on the modem. I expect
that the web server would become http://10.0.0.1 but this does not work. I am trying this from a end device that has a 10.0.0.5 address.
I have also chnaged the end device IP to a 192.168.0 address and tried accesing 192.168.0.1 with http but it does not respond.
It would seem to me that the web server is bound to 192.168.1.1 and that can't be chnaged? Is that the case?
Thanks
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
