Reply
Highlighted
Follower
C7100v compatible harddrives?
Hi, I have a C7100v cable modem router. I can't find an external hdd that is compatible with Readyshare.. There is a compatibility list for the C7000--will those drives work with the C7100v?
Message 1 of 2
Highlighted
NETGEAR Employee
Re: C7100v compatible harddrives?
yes, most of the drives will work. Ideally choose lower TB/GB, since higher TBs have problems to work with routers/gateways.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 259 views
  • 0 kudos
  • 2 in conversation
Announcements
