Orbi WiFi 7 RBE973
Reply
C7500 Hardware Problem?
tlee
My C7500 goes offline when I rotate one of the antennas past a certain angle.  This behavior is repeatable.  Here it is working:
Working lightsWorking lights
And here it is with the #2 ethernet light solid and no other activity:
Solid #2Solid #2
Should I be worried?
-Tommy
Message 1 of 5
Accepted Solutions
vkdelta
NETGEAR Expert
Re: C7500 Hardware Problem?
@tlee Tommy,
please PM me.
Message 5 of 5
All Replies
ROUTERS
I do not see a problem. you can get  idea on this video https://www.youtube.com/watch?v=41cTLHdrv8U
Message 2 of 5
tlee
So... that was an uneventful 8 minute unboxing video.
I failed to find any relevance to my original query where the router hardware appears to enter a fault state when the antenna is rotated a specific direction.
Message 3 of 5
DarrenM
Sr. NETGEAR Moderator
Hello Tlee
I suggest contacting support since this is a hardware issue they may be able to RMA the product for you.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 4 of 5
vkdelta
NETGEAR Expert
@tlee Tommy,
please PM me.
Message 5 of 5
Discussion stats
  • 4 replies
  • 1593 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
