- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7800 - Cannot connect to 2.4Ghz anymore.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7800 - Cannot connect to 2.4Ghz anymore.
1. you say some devices are connected to the 2.4gh? how many? which ones connect? which ones dont?
2. did you try changing the password? remove any special characters or spaces from the ssid/password?
3. when did it start? Was anything changed when it started?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried a simple factory reset and reinstall?
Push and hold reset for 7-15 seconds while its powered on
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the reset. Maybe the firmware change was enough to mess up the old settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK so a factory reset didn't work. Sometimes if I reboot the modem I can connect once on my phone but after that it says COULDN'T AUTHENTICATE CONNECTION. The computer still won't connect it says UNABLE TO CONNECT TO THIS NETWORK. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its still broadcasting during this? you can see the ssid?
Just not connect/use it?
Is it only on noe device? more than 1 device?
do wired devices have issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it only 1 device having issues?
Multiple devices?
Do some work and not others?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using any special characters/spaces in the password or ssid?
If so, change it.
Also, try setting your speed on the 2.4ghz from 1000mbps down a notch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried lowering the speed to 433. Worked once. After I disconnected and reconneced couldn't authenticate connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try changing it to something with no spaces.
Avoid spaces/special characters in the password as well
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
One reason it may not be fix is that there maybe a HW limitation on how many devices you can connect to one radio at a time. You can't just connect unlimited amounts of devices to one WiFi radio. There are some limtations. Not all wifi can handle large qualities of devices. Been like this for years. Nature of the beast.
One thing you might do is connect a wifi extender, like you did, this helps off load some of the wifi devices to a different wifi source to share the band width.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also depends on what your devices are doing as well. One device doesn't just take up 1 connection, there are many per device.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
