- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7800 Dropping ISP connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been having a recurring issue with the connection to my ISP randomly dropping. Here are some of the facts:
ISP: Wave Broadband
Plan: 1GB/10mb
Router never loses power
Usually comes back within 60 seconds
In Cable Connections I randomly notice that only some of the downstream channels are active, sometimes 5-16 out of 32. And I never pick up a OFDMA upstream
Cable Information |
Event Log
Time | Priority | Description |
2020-01-27, 17:34:55.0 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
2020-01-27, 17:52:23.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
2020-01-27, 17:53:09.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
2020-01-27, 17:53:09.0 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
2020-01-27, 17:53:13.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
2020-01-27, 17:53:19.0 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
Time Not Established | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
2020-01-27, 17:58:21.0 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=bc:a5:11:7f:77:94;CMTS-MAC=00:17:10:8d:f6:a1;CM-QOS=1.1;CM-VER=3.1; |
<tabindex=-1>Startup Procedure</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream OFDM Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7800 Dropping ISP connection
Wave has sent 3 techs on site and they all say the line is good. They're putting the fault on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a different modem/router, or try a modem only and external router. See if problem clears or pertists. Possible faulty C7800 as well and just needs replacing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for replying. I would like to state that I had another router previously that had the exact same symptoms as this one. Not sure of the exact model but it was an older Nighthawk. Support said I needed to update because it was DOCSIS 3.0 and my gig plan requires DOCSIS 3.1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try another C7800 to see if this problem persists.
IF a different modem did, there could be problems from where you modem is up to the ISP service box. Though I kind of doubt this.
Trying of another C7800 should reveal something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My ISP is sayig the same thing about this router. When they put a Arris 3.1 on line, the SNR look fine. But with this NightHawk C7800. The tech from Atlantic Broadband said something about the SNR is registering 0 downstream on the 25 port downwards yet on the Arris modem he used not issue with the SNR.
My symptoms are peroidic connection drops.
Ex. Monday between 8am - 6pm, every 30 mins. Yet, the next day til today Friday functions fine.
So i really wonder if its the router or the ISP.
This issue have been happening every month at this time (4-10th day).
Right now, its working fine.
Current System Time: Fri, Jun 05, 2020 15:24:06 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make contact with NG support about an RMA if thats possible.
@Jarudegirl1 wrote:Hello,
AM256 1 285000000 Hz 4.8 dBmV 38.8 dB 49 243 3 Locked QAM256 2 291000000 Hz 4.8 dBmV 38.6 dB 62 235 4 Locked QAM256 3 297000000 Hz 4.8 dBmV 38.5 dB 138 717 5 Locked QAM256 4 303000000 Hz 4.8 dBmV 38.4 dB 56 231 6 Locked QAM256 5 309000000 Hz 4.7 dBmV 38.4 dB 56 238 7 Locked QAM256 6 315000000 Hz 4.6 dBmV 38.3 dB 42 250 8 Locked QAM256 7 321000000 Hz 4.6 dBmV 38.4 dB 55 245 9 Locked QAM256 8 327000000 Hz 4.8 dBmV 38.3 dB 62 239 10 Locked QAM256 9 333000000 Hz 4.9 dBmV 38.4 dB 73 311 11 Locked QAM256 11 345000000 Hz 5.4 dBmV 38.4 dB 78 366 12 Locked QAM256 12 351000000 Hz 5.4 dBmV 38.4 dB 68 341 13 Locked QAM256 13 357000000 Hz 5.3 dBmV 38.2 dB 78 355 14 Locked QAM256 14 363000000 Hz 5.5 dBmV 38.1 dB 68 369 15 Locked QAM256 15 369000000 Hz 5.5 dBmV 38.1 dB 82 368 16 Locked QAM256 16 375000000 Hz 5.5 dBmV 38.0 dB 75 384 17 Locked QAM256 17 381000000 Hz 5.5 dBmV 38.0 dB 74 396 18 Locked QAM256 18 387000000 Hz 5.6 dBmV 37.9 dB 78 378 19 Locked QAM256 19 393000000 Hz 5.5 dBmV 37.9 dB 83 365 20 Locked QAM256 20 399000000 Hz 5.5 dBmV 37.9 dB 91 370 21 Locked QAM256 21 405000000 Hz 5.5 dBmV 37.8 dB 81 363 22 Locked QAM256 22 411000000 Hz 5.6 dBmV 37.8 dB 72 384 23 Locked QAM256 23 417000000 Hz 5.6 dBmV 37.7 dB 68 372 24 Locked QAM256 24 423000000 Hz 6.1 dBmV 38.0 dB 81 362 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 6 5120 Ksym/sec 32000000 Hz 46.5 dBmV 2 Locked ATDMA 5 5120 Ksym/sec 38400000 Hz 47.0 dBmV 3 Locked ATDMA 7 5120 Ksym/sec 25600000 Hz 46.5 dBmV 4 Locked ATDMA 8 5120 Ksym/sec 19200000 Hz 46.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords 1 159 Non-Primary 419600000 Hz 296 ~ 7895 130412291 57091 2 0 Other 0 Hz 0 ~ 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power 1 Other 0 Hz 0 ~ 0 0 0 dBmV 2 Other 0 Hz 0 ~ 0 0 0 dBmV Current System Time: Fri, Jun 05, 2020 15:24:06
