Orbi WiFi 7 RBE973
Reply
C7800 No work in Eurodocsis area
CihanKayacan
I got to use the C7800 model in Turkey. I can't use it now. When I called the Internet service, I was asked if they supported Eurodocsis.
Can I use this product in Turkey? Is the problem getting the Docsis 3.0 service? What should I do to use?
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: C7800 No work in Eurodocsis area
You will just have to ask your ISP if that modem is on there supported list of modems.
DarrenM
Message 2 of 3
CihanKayacan
If change US Freq Range 5-42 MHz to 5-85 MHz, this modem will be work. Its posslible change us freq range?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 557 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
