- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX80 can't upload 5GHZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 can't upload 5GHZ
As ErnestTheGreat appears to have retired from Netgear, is there anyone else from Netgear that can pick this thread up where he left it? He sent the logs to a CAX80 product engineer and the ODM team, but it all ends there. I really need this issue to be addressed or be forced to buy another non-Netgear router because this upload block on 5GHz is getting really annoying.
We have a few people in this thread that are willing and able (and eager) to help provide you with anything you need so you can improve your product and service, it's free QA for you and we hopefully get a product that works as it should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear will not fix the issue and they really don’t care.
- Mark as New
- Bookmark
- Subscribe
- Permalink
CAX80 won't upload 5GHZ network
I cannot upload on the 5ghz network with the cax80 modem. Browsing websites/small data transfer is fine. But large files (wetransfer, onedrive, google drive) does not work.
Just had a comcast tech out. No issues with the line. Modem reprovisioned. Etc.
Factory resetting modem does not resolve. Modem has latest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 won't upload 5GHZ network
Is Smart Connect enabled?
What channels are you using?
What devices do you have connected to the 5Ghz radio?
This is a known issue:
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tdalias
Is it still an issue for you? There's another thread about this (CAX80 can't upload 5GHZ network) and after providing logs and what not nothing happened. That thread is closed now, and I just bought a new modem router because I gave up on it, but decided to give it one more try and test run uploading on 5GHz on several OS and various browser and I have encountered zero issues now.
My guess is that they have fixed it somehow, I have no other explanation. I am still keeping my new Motorola modem router at end, but think of returning it if I keep a smooth 5GHz upload.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having this same exact issue. Xfinity has been out twice to check all the lines and no issues there. I have also factory reset my router and nothing changed. This started happening mid August 2022. I can email attachments, but I can't even upload a small screenshot to Slack unless I use 2.4G or the wire
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW version are you using?
NG is aware of the problem. Were hoping that next FW version will resolve this. I tested a beta and it fixed this issue however, presented a different problem on my modem which I had to send in my modem to get it fixed so I don't recommend using the beta version. I don't know when new FW will be forthcoming.
Just what works best for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah I have a workaround so I'm not too fussed, but I work from home so it has caused me a number of issues.
I have v2.1.3.5 and it says there are no updates available
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Keep whats loaded for now. Hopefully NG will come out with something. No idea when though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help and time! It's just really annoying when I bought my router a little over a year ago and spent a lot of money on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Understand. Will keep on them about this. From what I know, there is a fix, just needs to get into good working FW.
Keep an eye on the NG download page or here in this forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again! I work in customer service for a software company so I get it 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for understanding. We get the users frustrations as well. 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
I returned the Motorolla router/modem and of course afterwards my upload issues started again on 5GHz. Good to know, however, that there will be a fix soon. Is there a way to be automatically notified when a new FW is available?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not that a I know of. Keep an eye on the NG download page or here in the forums.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, will make a weekly reminder to check.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much for sending this over, but it looks like they may have rolled it back. I can't access the link and my app is still telling me there is no update available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Link is good. This update has to be manually installed using a PC and web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So weird, this is what I get. But I am on a Mac and not a PC if that makes a difference
I logged into routerlogin.net and tried to update from there and nothing was available
I also downloaded Firmware Version 2.1.4.2 https://www.netgear.com/support/download/?model=CAX80
and looked for the file ending in either .img or .chk per https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
But I only have Release Notes and CAX80-V2.1.4.2.bin in the zip file
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting.
The .bin file is what you use with a web browser when connected to the CAX web page and using the FW update web page to select this .bin file from your PC to upload to the router side of the modem. Do not attempt to open the .bin file. It gets sent thru the modems web page using the web browser.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
