Orbi WiFi 7 RBE973
Reply
CAX80 has no wifi now.
Dana259
I pushed the Wifi button to turn it on/ off but nothing.
Message 1 of 6
Accepted Solutions
Guru
Re: CAX80 has no wifi now.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 6 of 6
All Replies
Guru
Press the reset button on the back of the modem for 10 seconds then release then setup from scratch.
Does the default setup SSID name appear on a wifi device?
Message 2 of 6
Dana259
No name shows up on wifi
Message 3 of 6
Dana259
Resetting again to see if works.
Message 4 of 6
Dana259
Wifi is back after reset. Thanks
Message 5 of 6
Guru
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 841 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
