- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
CAX80 not getting full speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 not getting full speed
also wifi 6 ofdma works fine on my wifi 6 modem router from xfinity so it works. i went through 3 levels of tech support from netgear so they know its a problem with their firmware on wifi 6 mixed with comcast they are getting a firmware person to look into it and fix it. also my firmware is V1.1.0.41 and the cable firmware is V1.02.08.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey All,
Please note when I was using C6300 modem/router I had 100 MBbps plan from xfinity; I was getting 110 Mbps down/5 Mbps up. That tells me its not issue with Xfinity end; problem must be with CAX80's firmware or bootfile cannot handle the Gig speed specs as Xfinity level 2 support suggested ... but I will let experts conclude on this ...
Note: I was on hold for Netgear level 2 today for a little over 2 hours while watching Cheech and Chong's "Up in Smoke " movie. Since no one picked up, after that to release my frustration I went out to mow the lawn after a glass of wine (ok, half a bottle) 🙂
Hope ya'll having a great sunday but here is my data, let me know if I can provide anything else.
Firmware Version V1.1.0.41
Startup Procedure
Procedure | Status | Comment |
Acquire Downstream Channel | 483 MHz | Locked |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Security | Enabled | BPI+ |
Downstream Bonded Channels
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
1 | Locked | 256 QAM | 20 | 483000000 Hz | -1.0 dBmV | 40.4 dB | 0 | 0 |
2 | Locked | 256 QAM | 12 | 435000000 Hz | -0.7 dBmV | 40.4 dB | 0 | 0 |
3 | Locked | 256 QAM | 13 | 441000000 Hz | -0.7 dBmV | 40.4 dB | 0 | 0 |
4 | Locked | 256 QAM | 14 | 447000000 Hz | -0.6 dBmV | 40.5 dB | 0 | 0 |
5 | Locked | 256 QAM | 15 | 453000000 Hz | -0.6 dBmV | 40.5 dB | 0 | 0 |
6 | Locked | 256 QAM | 16 | 459000000 Hz | -0.8 dBmV | 40.5 dB | 0 | 0 |
7 | Locked | 256 QAM | 17 | 465000000 Hz | -0.7 dBmV | 40.5 dB | 0 | 0 |
8 | Locked | 256 QAM | 18 | 471000000 Hz | -0.6 dBmV | 40.5 dB | 0 | 0 |
9 | Locked | 256 QAM | 19 | 477000000 Hz | -0.9 dBmV | 40.4 dB | 0 | 0 |
10 | Locked | 256 QAM | 21 | 489000000 Hz | -0.9 dBmV | 40.4 dB | 0 | 0 |
11 | Locked | 256 QAM | 22 | 495000000 Hz | -0.7 dBmV | 40.3 dB | 0 | 0 |
12 | Locked | 256 QAM | 23 | 507000000 Hz | -0.8 dBmV | 31.7 dB | 152 | 0 |
13 | Locked | 256 QAM | 24 | 513000000 Hz | -0.6 dBmV | 34.6 dB | 0 | 0 |
14 | Locked | 256 QAM | 25 | 519000000 Hz | -0.2 dBmV | 37.9 dB | 0 | 0 |
15 | Locked | 256 QAM | 26 | 525000000 Hz | -0.6 dBmV | 38.4 dB | 0 | 0 |
16 | Locked | 256 QAM | 27 | 531000000 Hz | -0.5 dBmV | 40.1 dB | 0 | 0 |
17 | Locked | 256 QAM | 28 | 543000000 Hz | -0.2 dBmV | 40.5 dB | 0 | 0 |
18 | Locked | 256 QAM | 29 | 549000000 Hz | -0.6 dBmV | 40.5 dB | 0 | 0 |
19 | Locked | 256 QAM | 30 | 555000000 Hz | -0.4 dBmV | 40.6 dB | 0 | 0 |
20 | Locked | 256 QAM | 31 | 561000000 Hz | -0.2 dBmV | 40.6 dB | 0 | 0 |
21 | Locked | 256 QAM | 32 | 567000000 Hz | -0.3 dBmV | 40.5 dB | 0 | 0 |
22 | Locked | 256 QAM | 33 | 573000000 Hz | -0.4 dBmV | 40.5 dB | 0 | 0 |
23 | Locked | 256 QAM | 34 | 579000000 Hz | -0.4 dBmV | 40.6 dB | 0 | 0 |
24 | Locked | 256 QAM | 35 | 585000000 Hz | -0.3 dBmV | 40.5 dB | 0 | 0 |
25 | Locked | 256 QAM | 36 | 591000000 Hz | -0.1 dBmV | 40.7 dB | 0 | 0 |
26 | Locked | 256 QAM | 37 | 597000000 Hz | -0.4 dBmV | 39.7 dB | 0 | 0 |
27 | Locked | 256 QAM | 38 | 603000000 Hz | -0.5 dBmV | 39.0 dB | 0 | 0 |
28 | Locked | 256 QAM | 39 | 609000000 Hz | -0.4 dBmV | 39.7 dB | 0 | 0 |
29 | Locked | 256 QAM | 40 | 615000000 Hz | -0.1 dBmV | 40.4 dB | 0 | 0 |
30 | Locked | 256 QAM | 41 | 621000000 Hz | -0.2 dBmV | 40.4 dB | 0 | 0 |
31 | Locked | 256 QAM | 42 | 627000000 Hz | -0.4 dBmV | 40.4 dB | 0 | 0 |
32 | Locked | 256 QAM | 43 | 633000000 Hz | -0.6 dBmV | 40.4 dB | 0 | 0 |
Upstream Bonded Channels
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | Locked | ATDMA | 72 | 5120 Ksym/sec | 36700000 Hz | 43.0 dBmV |
2 | Locked | ATDMA | 69 | 5120 Ksym/sec | 17300000 Hz | 42.0 dBmV |
3 | Locked | ATDMA | 70 | 5120 Ksym/sec | 23700000 Hz | 42.8 dBmV |
4 | Locked | ATDMA | 71 | 5120 Ksym/sec | 30300000 Hz | 43.0 dBmV |
5 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
6 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
7 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
8 | Not Locked | Unknown | 0 | 0 | 0 | 0.0 dBmV |
Downstream OFDM Channels
Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
Extended Upstream Transmit Power is checked
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your downstream is 483Mhz. As seen with mine, it's over 700Mhz. I see near 900Mpbs with my CAX80 on the wire. This maybe one cause.
The CAX is well capable of handling 1Gb ISP services. If XF is telling you that from support, then they don't realize the CAX80 was tested by them and others on XF ISP services prior to going to market. XF would not have given approval for the CAX to operate on there services if it didn't.
Firmware Version | V1.1.0.41 |
Cable Firmware Version | V1.02.08 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Axl323, Carson_adkins, and ScoobyAgain,
I am reaching out to you all regarding your issues with the CAX80. I'd like to help and look into this further for you. May you send me a private message with your email address, serial number, and case number (if you've contacted support already).
Thank you,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend you reach out to netgear support and focus on Docsis 3.1/OFDM configurations for not achieving the advertised speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same issue. Xfinity XB7 Gateway in bridge mode connected to RAX45. Paying for 600 Mbps service.
If I run the XB7 in router mode, I am getting 720 Mpbs down. Once I run the Xb7 in bridge mode and connect the RAX45, speed immediately drops to 280 Mpbs.
There is obviously a firmware issue in one of these two devices - I am guessing on the Xfinity Xb7 Gateway side, since it is so new, but I wish they would fix it already. Don't like being stuck between two giant tech corporations whose products aren't playing well together.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post about this over in the RAX Forum for your model router:
This forum and thread is for the CAX80 which is a gateway modem/router.
Thank you.
@DKG-Atl wrote:I am having the same issue. Xfinity XB7 Gateway in bridge mode connected to RAX45. Paying for 600 Mbps service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please let us know how you got yours resolved. Would be helpful to know.
@carson_adkins wrote:
all I can say is that my problems have been fixed and am currently getting 1.1 Gbps on wifi 6 on my surface laptop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make contact with NG support if you haven't already. They should be able to help you out.
@theMuse77 wrote:
Can you elaborate or private message the fix please, waiting on firmware could take forever! I’m at a loss man...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just spent 1.5 hours on the phone with Netgear support tech engineer, had me change wireless channels and do a reset, of course no luck. Claims there is no beta firmware to fix my issue. I'm at wits end with this. No one is willing to help!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ask about an RMA.
@theMuse77 wrote:Just spent 1.5 hours on the phone with Netgear support tech engineer, had me change wireless channels and do a reset, of course no luck. Claims there is no beta firmware to fix my issue. I'm at wits end with this. No one is willing to help!!
- « Previous
- 1
- 2
- Next »
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
