Reply
CAX80 running FW 2.1.3.7 tells me Router Firmware Update is Available - but it isn't
My_Username
Tutor
The message appears at the top of the web interface. The CAX80 checks for an update when I click in the message but there is never one available. 2.1.3.7 is claimed to me the latest on Netgears site.
This has been going on for about 1 week.
Is this just another CAX80 "Feature"?
Message 1 of 11
Guru
Re: CAX80 running FW 2.1.3.7 tells me Router Firmware Update is Available - but it isn't
What FW version is currently loaded?
If your modem is working, I'd not worry about it.
https://community.netgear.com/t5/Cable-Modems-Routers/New-CAX80-Firmware-Version-2-1-3-7-Released/td...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 11
My_Username
Tutor
2.1.3.7 as per post title.
Message 3 of 11
My_Username
Tutor
Message 4 of 11
Kitsap
Prodigy
It appears 2.1.3.7 is the most recent for the router (RG) section of your device.
https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mod...
The screen snip you posted indicates no new update is available.  This is consistent with the Netgear information at the link above.
My setup: Comcast -> Netgear CM2050V -> Netgear R7800 (Voxel V1.0.2.98SF)
Message 5 of 11
My_Username
Tutor
A flag appears at the top of the screen telling me me a firmware update is available. It is clearly visible in the posted screen snip.
When I check for that update under Advanced/Administration/Router Update I am told no update is available.
Something is screwed up, how unusual?
Message 6 of 11
Guru
What happens if you power OFF the modem for 1 minute then back ON?
Might try a factory reset and setup from scratch and see if this clears the FW notification on the web page.
Message 7 of 11
Omnitron
Guide
Does the message go away if you manually flash the 2.1.3.7 firmware (vs just the auto update)?
Message 8 of 11
My_Username
Tutor
Shutting power down and booting back up changes nothing. I am not interested in resetting or reloading the same firmware and setting up from scratch. I'll just consider this part of the Netgear owner experience.
I should mention that this does not happen 100% of the time. I might pull the web interface up 4 times in a row and see this. I might see this 50% another time and I'm 0 for 4 this morning.
Oh well - it got this message to the web.
Message 9 of 11
Omnitron
Guide
This issue seems fixed for me, around the same time everyone’s CAX80’s stopped rebooting every day.
Message 10 of 11
Guru
Any progress on this?
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 451 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
