- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX80 show's NOW Only Power LED on
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all, I have a CAX80 that has only the power LED light on. Resets do not work and unable to access the unit at all to attempt a firmware load. Suspect hardware issue. Netgear will not allow me to send it in for repair since out of warranty period.
There is nothing wrong with my internet provider (XFINITY), because I ended up renting their equipment plug in and all worked
Is there any way to have the hardware repair?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just wondering. If you disconnect the modem from the ISP coax line and pull the power adapter from the wall out let for 1 minute then plug back in with out connecting the modem to the ISP coax line, does the modem front LEDs change behavior at all?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80 show's NOW Only Power LED on
Thanks for reply, but is there a solution to this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you...I did send them messages on 7/8, but so far no response back. Such an unpleasant surprise for a this expensive piece of equipment to suddenly be non operational just a few months after the warranty expiration date.
I am hoping something can be done. 😡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear Support contacted me and nothing can be done. Did a lot of settings and resetting's. Unit out of warranty, but maybe I will be approve for a replacement unit. At this time I was told that this unit is out of stock with no ETA on restocking.
Thank you for your support on this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Thanks for letting us know.
I would personally go with a separate modem and router unit. Combo units are good and work well when they work. However when they go down it take down the entire unit and everything. Learned from experiences and seeing others with same thing.
Having a separate modem and router is more flexible and you don't have to deal with the Modems FW as ISP take are of that when they should. Users are in control of the external routers FW and configurations. Makes management a bit easier IMO. If something happens, usually not both units go bad at the same time. Just have to troubleshoot either unit which isn't to hard. Its either a ISP service line issue, bad modem or bad external router, if and when that happens.
