Orbi WiFi 7 RBE973
Reply
CG3000v2 Port forwarding / Bridge Mode Issues
SeanInOZ
I have a optus supplied Netgear CG3000V2 Modem / Router.
I have managed to setup port forwarding successfully on this, however it appears that every time there is a power failure the unit forgets that port forwarding has been configured (even tho I can still see the settings) and I need to mess around using new, previously unused port numbers to get port forwarding to work again.
I decided to put the netgear into bridge mode and use another router for the port forwarding functionality but it appears that the pass thru from the netgear to the new router isnt happening. Whilst I get internet access (different IP to previous IP) I still cannot get port forwarding to work.
Anyone had these issue before ?
Regards
Sean
Message 1 of 3
Retired_Member
Not applicable
Re: CG3000v2 Port forwarding / Bridge Mode Issues
Contact Optus support.
Message 2 of 3
SeanInOZ
Optus support said this is an advanced feature that they don't provide support for.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3239 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
