Reply
CM 1000 VPN?
jghayes
CM 1000 VPN?
I have CM 1000 and I am trying to figure out if it is VPN capable.  Does it have a VPN built in?  I checked and it is not compatible with Express VPN.
Thanks
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 4
Guru
Re: CM 1000 VPN?
The CM1000 is a modem only. No router or VPN featuers. VPN would be handled at a router or connected client level and would just pass thru the CM modem.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CBR750 Modem | Wifi Router CBR750(v.7) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
jghayes
Re: CM 1000 VPN?
ok, I'm a networking rookie.  My modem passes to a Ubiquiti USG gateway so I'm assuming that is where the VPN will reside.
Message 3 of 4
Guru
Re: CM 1000 VPN?
You'll need to contact the mfr of that gateway for help and information regarding VPN.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 602 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
