- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000 Capped at 400megabit Comcast Gig speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I spent 2 hours on the phone with some "tech" saying its my modem thats the problem or its my wiring and i know for a fact hes wrong. All wires in my home are cat6a and the cox cables are brand new. I had full 900ish mega down and 40 up for a bit but then it started to slow. I still get full 40 up but my down speed was about 100-300 on so many sites. literaly every site said the same thing, exept comcasts own site which said i was getting 900 down and 40 up. The guy on the phone insists that my modem is broken and I need to RMA it with Netgear. Well to this day (all most 2 months later) its still slow and when i had it looked at i was told that it was perfect. So can someone help me figure this out. is it comcast or do i have a bad modem.
Time | Priority | Description |
2018-04-19, 17:50:12 | Notice (6) | CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: �; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-04-19, 17:50:11 | Warning (5) | Unicast DSID PSN startup error |
2018-04-19, 17:49:55 | Warning (5) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-04-19, 17:49:49 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 .;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
2018-04-14, 20:07:11 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
2018-03-08, 07:27:03 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-03-08, 07:27:03 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-03-08, 07:25:43 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-03-08, 07:25:23 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-03-08, 07:25:23 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
2018-03-08, 07:24:03 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=58:97:bd:2e:4d:60;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=b0:39:56:4a:d5:f0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1000 Capped at 400megabit Comcast Gig speed
Are you able to post your power levels and the uncorrectables?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Frequency start Value | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Startup Procedure | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream OFDM Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream OFDMA Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is odd you are getting no readings on the Upstream power levels. Also the uncorrectables is cut off in the picture do you see large numbers in this area?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is all that is on that page. Comcast controls the updates and boot files aparently also the event log is clear of anything. All that I just posted is all that I seel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All the things I've posted so far is all that i see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
At this point you may need a ISP tech out to check the connections out side the house could be something bad in box out on the street.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
See those unlocked channels? they should be locked. All those sync timing issues? You need a line tech to look at that. If a tech worth their salt comes out and does a line test, no way in hell, its gonna pass. They'll tell you flat out they need someone to come to take a look at the line.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've contacted Comcast about this and they came and relpaced the coax fittings in my home. Either way the lines coming from the street have yet to be addressed but I'm expecting them to replace them soon. I'll either notice right way with the proper speeds or I will end up calling them again in a week or so asking if its been done.
I'm also posting all my data for over a year with graphs and other things over at: https://linustechtips.com/main/topic/925281-slow-gig-speed/ so I recommend you take a look.
