Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000 Modem not connecting to ISP
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2022-05-13
02:38 PM
2022-05-13
02:38 PM
When I turn on my modem the power light turns solid green, then all the lights underneath blink green and then blink amber before all off them turn off and just the bottom light with the 3 squares and a line between them turns solid amber and then it just starts all over doing this cycle without ever connecting or stopping unless I turn it off or unplug it. I had no issues before and this happened after I had to move the modem and router to a new room. I've tried power cycling and the reset button.
Solved! Go to Solution.
Message 1 of 4
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2022-05-13
03:19 PM
2022-05-13
03:19 PM
Nevermind I figured it out. My idiot self had the power cable for the modem and another wireless signal thing mixed up and when I switched them it worked. Consider this case solved
Message 4 of 4
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2022-05-13
03:04 PM
2022-05-13
03:04 PM
Re: CM1000 Modem not connecting to ISP
Disconnect the ISP coax cable from the modem.
Press the reset button in back for 10 seconds, then release.
Does the power LED turn ON and the Download LED blink only with out other LEDs turning on?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router SXK30(v.122) and R8500(v.158) Router Mode and Wired Backhaul | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2022-05-13
03:12 PM
2022-05-13
03:12 PM
Holding the reset with the isp coaxial did not affect the light cycle. After the blinking the ethernet light will be solid amber and then a few seconds later the power will light up solid green and then the cycle resets with just the power being on and then the blinking
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2022-05-13
03:19 PM
2022-05-13
03:19 PM
Message 4 of 4
