- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000 Security and logging bug
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased a CM1000 with which I am experiencing issues.
I am in the process of resolving issues with Comcast that are resulting in the modem continually logging errors. Eventually the log screen shows zero errors which would lead one to believe that the issues have been corrected, however, that is not the case. Once the log is cleared, the errors resume or the modem fails to load the log due to a parsing error. The modem appears to run out of RAM for the purpose of logging about every 24 hours.
Furthermore, the modem password resets to the default password everytime the logging issue occurs opening the device to attack.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1000 Security and logging bug
What FW are you on? what logs are you referring to? Event logs?
Can you reproduce password reset issue every 24 hours?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the only log that I see in the modem is the event log under advanced. Firmware is V2.01.15.
I can't say that the password reset is every 24 hours, but it regularly occurs about every day. I can safely say that it always happens within 48 hours, and is almost definitely related to the issue with the log. I believe the log issue is related to the size of the log rather than a specific time period.
I'm betting that this would not occur if the log did not overflow.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Danny80916, that appears to be a different issue. In my case, all logging stops until I clear the log or reboot the modem.
