Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000 goes from green flashing LAN to red flashing LAN. Internet speed drops from 235Mbps to 94Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-02-23
06:40 AM
2017-02-23
06:40 AM
Within 12 hours of a modem reset. My internet speed goes from maxing out my 200Mbps comcast connection to 94Mbps. I've noticed the LAN lights on the modem start out flashing green, but change to flashing red. Does this mean my modem connecting to my router is going from a !Gbps connectgion to a 100Mbps connection? That's what it feels like.
Hardware Version | 2.02 |
CM1000 | |
Firmware Version | V2.01.15 |
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-02-24
05:04 PM
2017-02-24
05:04 PM
Re: CM1000 goes from green flashing LAN to red flashing LAN. Internet speed drops from 235Mbps to 94
it should be Green > Amber..
Amber means it is operating in 10/100 Mbps mode. you want to check your Router is ok and also swap ethernet Cable. Some times, router's WAN port may negotiate lower rate (rare)...
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-02-25
11:32 AM
2017-02-25
11:32 AM
Swapping the cable is a good idea. Netgear tech support suggested I contact Comcast and have them check the power levels to the modem as well. But it makes more sense that it might be a cable/router issue. Tplink c7 archer router was stable at 130mbps with my previous modem.
Message 3 of 3
Announcements
