Orbi WiFi 7 RBE973
Reply
CM1100 etherchannel
netmask001
CM1100 etherchannel
I am going to be using WAPs at home. how do I connect my CM1100 to the WAPS?
I want to connect the CM1100 to a cisco switch using a etherchannel.
Can the CM1100 do this?
Also can the CM1100 be a DHCP server for internal LAN?
Then I will put my WAPS on the cisco switch
is the CM1100 just a cable modem and router?
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1
Message 1 of 2
antinode
Guru
Re: CM1100 etherchannel
   Half right.  It's a modem. Hence there's no "router" in:
> Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem-DOCSIS 3.1
   "a cisco switch" is not a very detailed description of anything.
   Assuming that "a etherchannel" means an Ethernet cable, that's
probably a bad idea.
   Add a router?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 548 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
