- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1150V DHCP fail to router every few minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Equipment: CM1150V with Comcast, firmware is 2.02.04.
With increasing frequency, DHCP to the router fails. I replaced the aging Wi-Fi router that it was connected to with a new one, thinking this was the problem. Unfortunately the failures continue. I also replaced the Ethernet cable with a brand new one. I have rebooted the CM multiple times over the last few days. The outages are now occuring every few minutes.
The cable connection is good. The CM reports downstream power >= 1.1 dBmV, and the SNR is >= 41.1 dB with all channels locked. The event log doesn't show anything exceptional. The last messages this morning are:
Time Priority Description Mon Sep 28 06:26:54 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Mon Sep 28 06:26:49 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1;
but i'm pretty sure this is when I power-cycled the modem this modem.
This modem is serving what is now a typical pandemic household, with kids and adults connected to their respective VPNs for school and work.
How can I troubleshoot and fix this? It would be nice if I could capture more detailed logs from the CM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1150V DHCP fail to router every few minutes
do you have a screen snip of the cable connections page and the logs?
Also, is anything else plugged into the other 3 ports? I know it has more ports but the average consumer can only use port 1 because most ISP's only assign 1 public ip address. so unless you pay for more, are one of the lucky few who's isp does allow more (rare), have a business class line, or have a router that supports wan port aggregation, then only port 1 is usable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemansThanks for the prompt response. The only thing plugged into the CM is the router.
Here are the details from the Cable Connections page:
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 477000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 9 477000000 Hz 3.4 dBmV 42.8 dB 0 0 2 Locked QAM256 6 459000000 Hz 3.8 dBmV 43 dB 0 0 3 Locked QAM256 7 465000000 Hz 3.7 dBmV 42.9 dB 0 0 4 Locked QAM256 8 471000000 Hz 3.6 dBmV 42.8 dB 0 0 5 Locked QAM256 10 483000000 Hz 3.2 dBmV 42.6 dB 0 0 6 Locked QAM256 11 489000000 Hz 3.4 dBmV 42.7 dB 0 0 7 Locked QAM256 12 495000000 Hz 3.3 dBmV 42.6 dB 0 0 8 Locked QAM256 13 519000000 Hz 3 dBmV 42.2 dB 0 0 9 Locked QAM256 14 525000000 Hz 3 dBmV 42.4 dB 0 0 10 Locked QAM256 15 531000000 Hz 2.9 dBmV 42.4 dB 0 0 11 Locked QAM256 16 537000000 Hz 3.1 dBmV 42.5 dB 0 0 12 Locked QAM256 17 543000000 Hz 3 dBmV 42.4 dB 0 0 13 Locked QAM256 18 549000000 Hz 2.8 dBmV 42.4 dB 0 0 14 Locked QAM256 19 555000000 Hz 2.6 dBmV 42.2 dB 0 0 15 Locked QAM256 20 561000000 Hz 2.6 dBmV 42.1 dB 0 0 16 Locked QAM256 21 567000000 Hz 2.4 dBmV 42 dB 0 0 17 Locked QAM256 22 573000000 Hz 2.3 dBmV 41.9 dB 0 0 18 Locked QAM256 23 579000000 Hz 2.2 dBmV 42 dB 0 0 19 Locked QAM256 24 585000000 Hz 2.2 dBmV 42 dB 0 0 20 Locked QAM256 25 591000000 Hz 2.3 dBmV 42.1 dB 0 0 21 Locked QAM256 26 597000000 Hz 2 dBmV 41.9 dB 0 0 22 Locked QAM256 27 603000000 Hz 1.9 dBmV 41.9 dB 0 0 23 Locked QAM256 28 609000000 Hz 1.7 dBmV 41.8 dB 0 0 24 Locked QAM256 29 615000000 Hz 1.6 dBmV 41.5 dB 0 0 25 Locked QAM256 30 621000000 Hz 1.5 dBmV 41.6 dB 0 0 26 Locked QAM256 31 627000000 Hz 1.3 dBmV 41.6 dB 0 0 27 Locked QAM256 33 633000000 Hz 1.2 dBmV 41.5 dB 0 0 28 Locked QAM256 34 639000000 Hz 1.1 dBmV 41.5 dB 0 0 29 Locked QAM256 35 645000000 Hz 1.3 dBmV 41.7 dB 0 0 30 Locked QAM256 36 651000000 Hz 1.1 dBmV 41.5 dB 0 0 31 Locked QAM256 37 657000000 Hz 1.1 dBmV 41.5 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 36500000 Hz 41.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 30100000 Hz 41.5 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 23700000 Hz 40.5 dBmV 4 Locked ATDMA 7 5120 Ksym/sec 17300000 Hz 39.8 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0 ,1 ,2 ,3 32 690000000 Hz 1.0 dBmV 40.9 dB 1108 ~ 2987 22508462 8105875 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Current System Time:Mon Sep 28 09:39:49 2020 System Up Time:03:13:51
Here are the logs:
Time Priority Description Mon Sep 28 06:26:54 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Mon Sep 28 06:26:49 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 15:51:00 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 15:50:55 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 15:14:53 2020 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 15:14:24 2020 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 14:49:30 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 14:49:25 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 14:47:05 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Sun Sep 27 14:47:00 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Sat Sep 26 23:29:18 2020 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 6 7 8 32 34 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Sat Sep 26 23:29:13 2020 Warning (5) MDD message timeout;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 23:17:45 2020 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 23:17:45 2020 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 23:17:44 2020 Notice (6) CM-STATUS message sent. Event Type Code: 23; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 20:30:22 2020 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 20:30:17 2020 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 19:49:56 2020 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 19:49:46 2020 Warning (5) Dynamic Range Window violation Thu Sep 24 19:49:46 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 19:49:46 2020 Warning (5) Dynamic Range Window violation Thu Sep 24 19:49:46 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 19:49:46 2020 Warning (5) Dynamic Range Window violation Thu Sep 24 19:49:46 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 19:49:46 2020 Warning (5) Dynamic Range Window violation Thu Sep 24 19:49:46 2020 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=28:80:88:0F:FF:FF;CMTS-MAC=00:01:5c:95:bc:64;CM-QOS=1.1;CM-VER=3.1; Thu Sep 24 19:49:46 2020 Warning (5) Dynamic Range Window violation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: Strangely, the link dropped from 1000 Mbps to 100 Mbps. There is nothing in the logs that indicates why this might have happened. However, the link has been stable for just over an hour now. So now i've got two mysteries: why was the link dropping with the 1 Gb link, and why did it renegotiate a link at 100 Mb on its own?
I'll wait a little longer to be sure the link is stable, and then open a new thread for the 1 Gb to 100 Gb drop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd contact comcast to check the cmts and re-provision it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So i'm now pretty sure the issue is isolated to the cable modem. Using their troubleshooting tool, I had Comcast reboot the system from their end - not sure if that counts as reprovisioning. I did this a couple of times today. The link instability persisted.
The modem is not able to maintain a 1000 Mbps link to the router. As an exercise, I placed an unmanaged switch between the CM and the router. The port LEDs on the switch indicated that the router was able to maintain a 1 Gbps link, but the CM could only negotiate 100 Mbps.
If I force the router WAN port to 100 Mbps, then the link is stable.
What could be causing the CM to no longer handle a 1 Gbps link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
could be a couple things.
1. bad cable.
2. bad port/pins on the port
3. bad modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you change the cable?
does it drop down to 100M on switch as well?
is the modem in well ventilated area?
