Orbi WiFi 7 RBE973
Reply
CM1150V Not allowing network router to connect to Internet.
Psychox
Tutor
Today I bought a Netgear CM1150V Xfinity modem. (2nd of April 2020) Setup was easy. The firmware is the most up to date for today. The problem is the modem is blocking my routers from conecting to the internet. I have a Linksys EA8300, Cisco RV345, and Cisco E3000. Initally I hooked up the EA8300 wifi router and was unable to get internet to it. Then I hooked up the RV345 and had no internet problems other then no wifi. It worked great. I then hooked the EA8300 to the RV345 router and had wifi and internet on the EA8300 and RV345. It worked great for about 30 minutes. Then no internet to the EA8300 or the RV345. Then I hooked up the E3000 to the modem and again it worked great for about an hour then no internet. This whole time I had internet at the modem with no problems. I disconected the CM1150V and hooked up my old modem. I had internet on all my routers again. Then I hooked the CM1150V back up and did a reset to factory setings. I had the same problem I had to start with. I am able to use the RV345 again without any problems, but as soon as I hook a wifi router to it both get the internet blocked.
After contacting Comcast Xfinity they said, "there are no problems with my modem. It must be a problem with my router. And, since I own my modem they can't help me."
If it was a problem with my routers why do they work with my old modem. I checked for compatability issues before buying the modem and all these routers should work with no problems. I suspect Comcast Xfinity is using the firmware to detect and block wifi routers. Any ideas to fix this?
If I can't get it to work, sorry Netgear, but you can have your modem back. I will stick with my slow old one. When Comcast Xfinity has that much control over my network I don't want your product.
Model: CM1150V|DOCSIS 3.1 Nighthawk® Multi-Gig Speed Cable Modem for XFINITY® Voice
Message 1 of 15
Guru
Re: CM1150V Not allowing network router to connect to Internet.
SOunds like the CM modem maybe faulty. I would try another CM modem. Users can connect any external router to the modem and should get internet access and not be blocked after a period of time.
You might try resetting the CM modem and have the ISP send down there configuration file again and see if this clears the problem.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
IF this stil fails, Try another CM modem. Possible the one you have is just faulty.
Message 2 of 15
Psychox
Tutor
@FURRYe38,
Right now I have 3 Cisco RV345 routers running in a chain. Everthing works, but as soon as I hook up any of my wifi routers to the chain it will drop internet to all of the routers between the modem and whatever Cisco RV345 I plug into. The RV345 does not have wifi and works as long as I do not hook up a wifi router to it. The first RV345 has network CCTV cameras and a CF-WA900 comfast router with six 100w linear ampliphires running to three 2.4g 60db omni antennas and three 5.8g 60db omni antennas on a 25 foot communication tower. The second RV345 has 6 computers hardlined and a Linksys EA8300 wifi router hooked to it. The EA8300 is hooked up wifi to four smart TV's. The 3rd RV345 hardlines two servers and a Cisco E3000. The E3000 is hooked up wifi to 5 tablets and an Ipad. My ISP (Comcast Xfinity) has re-pushed the firmware to the modem four times. I still had the same outcome. I thought about it maybe being the modem and picked up another one from Best Buy today 3rd of April 2020. Still having the same outcome after two more firmware push tries. I think it is the ISP firmware and not the modem. I think it is their way of trying to get me to rent their wifi modem or pay for wifi on their system and get more money out of me. FYI: That will never happen. I will switch to T Mobile and run a hotspot router before that ever happens.
Message 3 of 15
Psychox
Tutor
@FURRYe38,
Also, the tech I talked to at my ISP (Comcast Xfinity) kept trying to get me to rent an Arris modem from them. He asked me about 10 times if I wanted to try and rent one.
Message 4 of 15
Guru
So what happens if you connect just 1 wifi router the CM modem along with your wireless devices?
Message 5 of 15
MacroLogo
I had a very similar problem. I ultimately solved it by having my entire system  connected as I wanted it (i.e., the ethernet cable connected between the cable modem and the wifi router), with everything powered on, then called Comcast/Xfinity on my cell phone. I verbally spoke the option "no internet connection" when the robot asked me to describe my problem at which point the robot reset my entire system remotely. It sent me a text message saying it was starting the reset and then hung up on me. Ten minutes later I got a message that my system had been reset. At that point, I was able to go through Netgear's protocol of setting up my new Wifi router, which included updating the Wifi router's firmware. It was however, obvious as soon as Xfinity had reset my system that things were going to work.
Further comments
1. I spent many hours trying to troubleshoot this before hitting upon the relatively quick solution above.
2. I called Comcast/Xfinity twice before my successful call. For these first two calls I had said I need to "Activate my system". Each time I was connected to a human. The first human got my information then tried to transfer me to an activating agent at which point my call was dropped by Comcast. The second agent insisted that I did not need to activate, said she had been working for Comcast for 20 years, that she could not possibly be wrong, and hung up on me. So the trick was getting a robot, not a human.
3. Comcast documentation and human advice seem to convey that once the cable modem is working, it doesn't matter what is hooked up downstream. This is demonstrably false. I was able to hook up only one device at a time (my old wifi router, or my computer directly, or my new wifi router, or another computer). In order to swap these out, I needed to use my cell phone to call Comcast and have the robot reset my entire system. In the case of directly connecting a computer, there was a way to do this directly form the computer browser, but I couldn't figure out how to do this directly with a wifi router.
4. Before hitting on the correct solution, I tried a number of tricks, like setting a static IP to the router equivalent to the IP that Comcast had previously assigned my desktop computer. But I was not successful.
5. I was getting close to giving up and surrendering and buying an Xfinity Gateway. Xfinity definitely has a conflict of interest in providing advice or making it easy to connect your own gear.
6. It wasn't strictly true that I had "no internet connection" because I did have a connection through my desktop computer. I just couldn't figure out how to change that connection to the wifi router.
7. I was not able to update the Netgear Nighthawk router's firmware until after I had the system reset by Comcast.
8. Merely turning off the power to the cable modem does not work. It has to be reset remotely by Comcast.
9. After posting my original message in another thread, someone suggested a Factory Reset of my cable modem (using the button on the modem) would work equivalently to having Comcast reset my modem remotely. I did not try this, but I suspect it would not have worked for me, as there seems to be a phenomenon of Comcast knowing what I have plugged in downstream. Not sure how, maybe through the MAC address. So you might try the factory reset button. But it is probably just as easy to have Comcast do it remotely unless you don't have a way of phoning them with a cell phone or other phone.
Message 6 of 15
Guru
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure to power OFF the modem for 1 minute them back ON.
You can factory reset the CM modem your self as well. There is a reset button on the modem. Press and hold it for 15 seconds then release.
Message 7 of 15
Psychox
Tutor
My brother is one of them high IQ computer nerds with no education. After downloading the firmware off the modem. He found a line where Comcast was in fact blocking use of an external wireless router. They want you to rent their equipment and this is how they do it. I had one of two choices. I could rewrite the line in the firmware and have to rewrite it every time Comcast did a firmware update or set my router up as an access point so eveything on that router was pulling an IP from the modem. I doing this I ended up buying another router just to use as an AP. Once I setup the AP I was able to trick the system and hook up my other 4 routers as normal routers and not in access point mode.
It's funny people ask me all the time, "why do you want to sit behind 4 routers."
Here's why: I use them as part of a custom firewall. I have an old pentium 3 sony viao desktop hooked to all 4 routers. It does a few different things, but its main peruses are to scan my network for trojan programs, nesting programs, and foreign mac addresses that are not in a set list. When it finds a foreign mac address it drops a nesting program with a trojan virus onto the device with the foreign mac address. The nesting program does 4 things. 1. It replicates it's self and sends out copies to every device on the foreign devices network including the modem and routers. 2. It roots its self into the firmware and bios of every device on the network. 3. Its locks down all the data on all the hard drives in the network. 4. It forces an over clock of the frontside bus to 8.3ghz on all computers on the network.
I have to love my little brother for this program. It runs on MSdos, but it won't run in windows. It is a patented and copie written stand alone operating system that has never been distributed.
Message 8 of 15
Guru
CC allows users to connect routers of there choice to there modems or user bought modems. There would lots more people posting problems with CC if this was really blocking users from connecting external routers.  Most common configurations and normal for most house holds is having 1 router. Thought I presume you could have more if you wanted too. Thought this would be problematic at best. Seems to be a problem in your case which nobody else seems to be having.
Good Luck.
Message 9 of 15
Psychox
Tutor
@FURRYe38 Yes you can hook up a router, but the Docsis 3.1 on Comcast blocks them in a normal router config. If you use the Access Point mode on your router you can use them all you want, but you will lose a level of security. This is because your router is assigning the IP address given to it from the modem. So, if your modem has a user control IP address of 10.0.0.1 and you run your router in Access Point mode all your devices are going to be 10.0.0.2, 10.0.0.3, 10.0.0.4, etcetera. However, if your router is running in a router mode you have an extra level of security. This is because a router in router mode is giving your devices a different IP address. So, your router asks your modem for an IP address. The modem gives it 10.0.0.2. Most routers have a user control IP address of something like 192.168.0.1. If the router is in router mode and not in AP mode it is going to give all your devices IP addresses of 192.168.0.2, 192.168.0.3, 192.168.0.4, ectetera. It is much harder to find a device behind a router when you're hacking someone's network. Because, the router user controls IP addrss might be set to 75.75.75.75 (FYI: this is comcast's DNS server IP out of Chicago) and all their devices might be running 75.75.75.76, 75.75.75.77, 75.75.75.78, etcetera. The router user control IP address can be anywhere from 1.0.0.1 to 255.255.255.254. There are programs that can scan for the IP addresses of the devices, but it's going to take a long time to get it done. If the person you are hacking is sitting behind multiple routers before you can get to their devices it's going to take some time to get to them. There are ways to drop the time it will take such as in PvP game play or through a messanger program on social media, but not everything you want to hack is going to be that easy.
Message 10 of 15
Guru
Something you might check with other CC forums and see. I've seen many users post about having CC and use there own modems and own routers with little problems. I know this for sure as I've beta tested for NG had they ask us which ISP we use before we start testing. CC is one on a short list the NG asks us about. Seems like something maybe your doing or using isn't configured right. Again, if CC was doing this, there would be many users angry about not being able to use there own bought products on there network.
Message 11 of 15
Psychox
Tutor
@FURRYe38 Definitely not in my setup. Here is a little history on me. I'm 44 years old. My mom is a 37 year retired IBM employ. I used to take old IBM computers out of the trash at IBM and build them. I started doing this when I was 9. I started learning binary code when I was 11. I am a Cisco certified network tech and have been for 13 years. I finished my BA in computer science at WGU 5 years ago. I highly doubt my setup is wrong.
Message 12 of 15
Guru
Well regardless of experiences, there seems to be something going on with your setup. There have been others in this forum that report using there own modems (NG or other Mfrs) with there own routers with CC ISP. Again, I for one see other users in beta testing that have CC as there ISP and have not reported or seen issues with CC ISP services. For a couple of modes we tested was the Orbi CBK40 and C7800. I would presume that maybe CC maybe singling you out and maybe doing something to block you or have cause to do this since your configuration maybe doing something nefarious or causing problems when on there service. You seem to be the only one having this issue and posting about it while others are not. Maybe at one point CC was blocking customer routers, however I've been doing this for many years and haven't seen complaints nationally about CC and blocking customer owned routers. I know that historically, CC has had very bad customer services and there ISP owned gateway wifi routers also were allowing there wifi router access to neighboring users to piggy back off there modems. Not sure if there still doing that or not. CC is not around my region, thankfully.
Seems like CC maybe only doing something with you and your configuration. Something you should contact the ISP about. Talk to a high level support tech and see why they are blocking your owned products. Only they can help you with this.
Message 13 of 15
MWR1424
I am having this same problem.  All was working when it was setup but was not getting the speeds that i was paying for.  Called and CC told me it was my equipment, sent a tech our later and before he left, i was getting slower speeds and the wifi stoped working and I have not been able to get it back up.  Even tried a new wifi device just to verify it wasn't my equipment.  Everybody i have talked to at CC says that they can not help because it's not there equipment.  (Do you want to rent ours?)  What do you think my answer is....
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 14 of 15
Guru
Which modem do you have?
What FW version is loaded on the modem?
Tested with PC wired dirctly to the modem? Power OFF the modem. Disconnect any wifi router. Connect 1 wired PC to the WAN port#1. Power ON the Modem.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 4247 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
