- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
CM1150V Upstream Channel Problem with Xfinity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1150V Upstream Channel Problem with Xfinity
yeah,
Comcast is in the process of reverting me back to 2.02.03 after they said they could not reporduce it themselves.... which is funny since I can reproduce it just fine with two CM1150V modems at two different houses (but on the same CMTS) we will see if it goes right back to where it was when they get the firmware upgraded again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any updates on this - I get intermittent outages all the time and the uplink is still flashing green (although all channels are locked)? Comcast has changed the entire line, switched my port, and I am still experiencing intermittent (but regular) internet drops (ever 2 hours or less).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would be best to contact NG support if you've had the ISP check the lines and signal up to the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the modem status all looks fine (channels locked, online LED solid)... Then the "every 2 hours or less" outage would make me suspect a DHCP issue rather than anything with the modem. You should have a single device (Router) connected directly to the modem, with a good quality Cat6 cable, with no switches/hubs in between. Some Router firmwares have a few optional settings for the DHCP client, so check those as well if your ISP has any special requirements.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you guys that are having issues with flashing upload led's after online report the issues to comcast direct at DSLReports? ComcastGeno there has an open ticket with me and netgear on this issue and the more detail they get the better
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.dslreports.com/forum/comcastdirect
I will give it a shot... I worked with a Comcast rep (via their forum's direct messaging) and had a ticket open with Negear. Both did a lot of finger pointing at the other, and both eventually ended with no resolution -- my speeds and reliability are fine, so both took a "don't worry about it" attitude in the end. But either something is wrong (like a channel flagged unusuable, though still locked) OR the firmware is reporting a problem when there isn't one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear had comcast put a test firmware on my modem and it actually solved all the issues... just got it tonight, no more partial service no more flashing upstream LED
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cool! Did they give any indication of how close that version is to production release?
- Mark as New
- Bookmark
- Subscribe
- Permalink
no idea, but the firmware does seem to have an impact on my download speed.... I'm getting about 70% of my normal speed down but 100% of my normal upload speed
- « Previous
- 1
- 2
- Next »
