- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM2050V 2.5 Gbps Multi-Gig Connection to RAX200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I am not sure which connection I need to make on the back of my RAX200 in order to use the 2.5Gbps from the modem. Do I connect the modem to the multi-gig port on the back of the RAX200 or to the internet port? I know I must also change the settings in the router's configuation page to 2.5 multi-gig.
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as solved so others will know.
Enjoy,
@CAmbr52342 wrote:
Thank you! It works.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM2050V 2.5 Gbps Multi-Gig Connection to RAX200
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
I would review the installation guide and user manual for the RAX200. I believe the 2.5Gb port can be used for the WAN side. You'll need to check for any configurations though.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I will try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the cm2050v is already activated, then connect it to the multigig port on the back of the rax200. you'll need to change the wan port in the settings to the multigig port and reboot both devices after its been changed.
I've done it with my cm2000 on both my rax200 and my raxe500. works great.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
glad to hear it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy,
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
