Reply
CM600 High Speed Cable Modem need to change the LAN setting to bridged
ThaDon11206
Follower
I added Norton Core and it wants control of services, I need to get into settings and change LAN to bridge mode. Can't access web over wireless now. So need best solution to fix this.
Model: CM600|CM600 High Speed Cable Modem
Message 1 of 2
vkdelta
NETGEAR Expert
Re: CM600 High Speed Cable Modem need to change the LAN setting to bridged
Cm600 is "bridged modem". It does not do any routing.
you will need to either correct directly to your modem or fix your router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1629 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
