- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM600 Spectrum to Cox firmware issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM600 Spectrum to Cox firmware issue
Is the modem working on there network? If so, they should be able to see it. Please contact them for help and information regarding this. Cable ISP handle all FW needs for cable modems.
Try a factory reset on the CM modem.
Have them de-provision it on there system, then have them re-provision it.
Besure there are not coax cable line splitters between the modem and ISP service box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see. You might contact NG support to see if there is anything that can be done by them. I presume there may not be anything. Might ask them if there is some way they could get factory FW on it if you were to send it to them. Even if they do that kind of thing. That would take a bit and you'd be with out internet.
https://www.netgear.com/mynetgear/registration/login.aspx
I think thats kind of a bad move for an ISP to put FW on a user bought router which makes it not usable on other ISPs should the user have a need to move to a didferent ISP.
Is there a Spectrum office that you can go to and talk to someone about this? Possible they could take the modem directly and load it back with factory FW.
Some ideas.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Irrespective of the FW, Cox should be able to see the modem as long as modem is online.
Just make sure modem is online.
also, post the event logs and DOCSIS power table screenshots.
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
