- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM700/Nighthawk Dropping Internet + DoS/WLAN access rejected spam
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of these problems began showing in the logs a few minutes after updating to V1.2.0.24_1.0.1. My internet has been disconnecting multiple times a day (modem loses connection).
In the logs I see:
1. Multiple [DoS attack: ACK Scan] from various IP's.
2. Multiple [WLAN access rejected: incorrect security] from my iPhone's MAC address
3. Multiple [WLAN access rejected: incorrect security] from 16 different unknown MAC addresses (a little concerned about this)
I can post the log if necessary but it's very long (6 days worth). Attached is a picture of the unknown MAC addresses that have been rapidly trying to connect to my wifi (which has a password).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM700/Nighthawk Dropping Internet + DoS/WLAN access rejected spam
Not in the router logs but the logs of the modem do you seen any T3 or T4 timeouts?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I never knew I could login to the modem like this so I'm a bit unfamiliar with the data. Unfortunately, I recently rebooted the modem to regain internet connection which seems to have cleared the logs. I do see:
No Ranging Response received - T3 time-out
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Downstream
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | UnCorrectables |
1 | Locked | QAM 256 | 17 | 603000000 Hz | -7.7 dBmV | 37.3 dB | 0 | 0 |
2 | Locked | QAM 256 | 18 | 609000000 Hz | -7.7 dBmV | 37.3 dB | 0 | 0 |
3 | Locked | QAM 256 | 19 | 615000000 Hz | -7.2 dBmV | 37.3 dB | 0 | 0 |
4 | Locked | QAM 256 | 20 | 621000000 Hz | -7.4 dBmV | 37.3 dB | 0 | 0 |
5 | Locked | QAM 256 | 21 | 627000000 Hz | -8.0 dBmV | 37.3 dB | 0 | 0 |
6 | Locked | QAM 256 | 22 | 633000000 Hz | -8.2 dBmV | 36.6 dB | 7 | 0 |
7 | Locked | QAM 256 | 23 | 639000000 Hz | -7.7 dBmV | 37.6 dB | 7 | 0 |
8 | Locked | QAM 256 | 24 | 645000000 Hz | -8.2 dBmV | 37.3 dB | 0 | 0 |
9 | Locked | QAM 256 | 25 | 651000000 Hz | -8.2 dBmV | 37.3 dB | 0 | 0 |
10 | Locked | QAM 256 | 26 | 657000000 Hz | -8.2 dBmV | 36.6 dB | 0 | 0 |
11 | Locked | QAM 256 | 27 | 663000000 Hz | -8.2 dBmV | 37.3 dB | 0 | 0 |
12 | Locked | QAM 256 | 28 | 669000000 Hz | -7.7 dBmV | 37.3 dB | 0 | 0 |
13 | Locked | QAM 256 | 29 | 675000000 Hz | -7.2 dBmV | 37.3 dB | 0 | 0 |
14 | Locked | QAM 256 | 30 | 681000000 Hz | -7.2 dBmV | 37.6 dB | 0 | 0 |
15 | Locked | QAM 256 | 31 | 687000000 Hz | -7.2 dBmV | 37.3 dB | 0 | 0 |
16 | Locked | QAM 256 | 32 | 693000000 Hz | -7.2 dBmV | 37.3 dB | 6 | 0 |
17 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
18 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
19 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
20 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
21 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
22 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
23 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
24 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
25 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
26 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
27 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
28 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
29 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
30 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
31 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
32 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | Locked | ATDMA | 2 | 5120 Ksym/sec | 30100000 Hz | 54.5 dBmV |
2 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
3 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
4 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
5 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
54.5 dBmV seems very high compared to the downstream values or is that normal?
Thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just experienced another drop in internet. Before it would fix itself but now it seems I need to do a full restart to get the internet working. I was able to grab the log before restarting.
Modem Logs:
Jul 31 2018 07:08:17 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:08:17 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:08:46 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:08:47 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:09:31 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:09:31 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:10:04 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:10:04 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:10:45 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:10:45 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:11:17 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:11:17 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:11:47 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:11:47 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:12:23 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:12:24 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:12:55 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:12:56 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:13:40 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:13:40 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:14:20 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:14:20 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:15:02 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:15:02 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:15:42 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:15:42 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:16:11 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:16:12 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:17:04 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:17:05 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:17:36 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:17:36 Critical (3) No Ranging Response received - T3 time-out
Jul 31 2018 07:18:28 Critical (3) Unicast Ranging Received Abort Response - initializing MAC
Jul 31 2018 07:18:28 Critical (3) No Ranging Response received - T3 time-out
And here are some of the router logs. The logs were empty up until July 20th when I upgraded to the latest firmware, except for one event in May. Not sure if this is a coincidence or not. This is from the same time as the modem log (router time is behind 3 hours). Note that this is how the logs look even when I'm not having issues. The other day it seemed to be allowing access to my phone every 5 minutes.
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:31:49
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:30:34
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:29:17
[Internet connected] IP address: xxx.xxx.xxx.xx Tuesday, July 31,2018 04:28:47
[Internet disconnected] Tuesday, July 31,2018 04:28:04
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:28:02
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:26:35
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:25:19
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:23:58
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:22:41
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:21:09
[Internet connected] IP address: xxx.xxx.xxx.xx Tuesday, July 31,2018 04:20:09
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:19:52
[Internet disconnected] Tuesday, July 31,2018 04:19:02
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:18:35
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:17:14
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:15:57
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:14:41
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:13:22
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:12:05
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:10:49
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:09:25
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:08:07
[Access Control] Device [MY-PC] with MAC address [MAC] is allowed to acc Tuesday, July 31,2018 04:06:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you have alot of timeouts this is typically a connection issue with the ISP something could of happened to the lines or the cable box out in your neighborhood you will want to have a ISP tech come check the levels and maybe investigate your area.
DarrenM
