- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cable Modem Router stopped working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cable Modem Router stopped working
How do you mean the coax fell out? Did the coax wired come out from its connecting screw plug jack? If so, possible ground and center wires maybe touching when they shouldn't be. Id have someone check that connetion to be sure it's correctly wired and the screw jack is in place correctly.
Power OFF the modem. Pull power adapter as well. Disconnect the coax screw jack from the modem fully. Disconnect ALL LAN cables as well.
Power ON the modem WITH OUT the coax connected. Do all lights turn on all the time or just the power and do the other LEDS start to blink?
Try pressing the reset button for 10 seconds then release with out coax cable connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried replacing the coax cable and then rebooting the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
are you able to get the cable connections page info and the event logs?
that helps us see if its connected and the strengths.
