Orbi WiFi 7 RBE973
Reply
Cable Modem
majz
Follower
Cable Modem
Purchased my modem in March.  The modem is constantly resetting.  Looks like I am out of luck on getting any kind of support since I didn't buy extended support or warranty.  Any ideas?  Do I just need to purchase a new different brand?
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 3
Re: Cable Modem
You could be having issues on your cable line itself, it could be an isp issue. Post your signal levels that you can get from the modem.
Message 2 of 3
Guru
Re: Cable Modem
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 544 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
