- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can not login to modem or connect on wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello there,
My name is Jay and I cannot currently login to my modem or connect to it wirelessly, I have restored to factory settings and attempted to set it back up but now it is giving me a weird ip address ( 50.82.53.1 ) instead of the normal 192.168.0.1 or 1.1, I can only access the internet through my hardwired desktop. My hardwired Ps4 also will not connect to the internet. I think the modem has finally died but didnt know if anyone had any ideas. My modem is a N300 cable modem/wireless
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can not login to modem or connect on wifi
I have also done a ping test and ipconfig/all shows 50.82.53.1 as my default but i also get fe80: : 217:10ff:fe83:fedb%4 right above it
- Mark as New
- Bookmark
- Subscribe
- Permalink
you are in bridge mode. may be you configured it by mistake.
two options:
1. Factory default it.
2. access the modem on 192.168.100.1 (you will need to set a STATIC IP on your network interface such as 192.168.100.10)
- Mark as New
- Bookmark
- Subscribe
- Permalink
after removing the RF cable i was able to restart the modem and get the 192.168.100.1 ip a login to the menu but once in it gives me little to no information. It basiclly will not allow me to access any of the other menus with in the modem. such as wireless connections and such. I tried resting it to factory from with in the menu but to no change. I tried setting it to router mode but it keeps resetting it self to the previous settings. the first time i set it to router mode and it restarted it gave me the full menu but as soon as i clicked anything it reset it self and went back to the previous settings and would not allow me to access that menu again. so I tried putting it to router mode again but the settings never stick. almost like an internal memory error or something. I still have access to the limited menu and the modem seems to be holding the 192.168.100.1 ip but i still cannot get the wifi or my ps4 that is hardwired to connect. i only have internet on my main desktop. contacted my isp and they cannot update the firmware because its a personal modem firmware is currently set at V1.01.05 but the latest firmware is V1.01.11
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
who is your ISP? what kind of service do you subscribe to?
did you request ISP to enable bridge mode for you? (I guess not)
Did it always happen ot just started happening?
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
