- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cant get desktop to connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Desktop wont connect to internet threw ethernet on the router. Ethier shows unidentified network or internet access it changes back and forth but no internet ether way. Can direct connect to modem and the desktop works great. Hooked a laptop to the router with a ethernet and it works so for some reason its only the one system. Shut everything off , unhooked all ethernets and let it sit and turned it all back on still nothin. Completely cleaned desktop back to a fresh install of windows 10. Installed ethernet drivers from a usb onto the desktop. Cant seem to figure it out myself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cant get desktop to connect
Tried both suggestion cant access router from that computer and the other didnt work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I posted the question like you asked and still havent gotten it to work. Used an external to install netgear genie on the computer to try and let it fix the issue still nothin..
Fixing network. Do not carry out other operations.
Fixing adapter:Intel(R) Ethernet Connection (2) I218-V. Please wait...
The adapter is disabled. Trying to enable it. Please wait...
Enable adapter:Intel(R) Ethernet Connection (2) I218-V successful.
DHCP enabled. Waiting for DHCP to complete..
Testing the gateway...
The gateway is valid
Testing DNS...
Gatway is invalid, trying to fix it...
DHCP server does not work.
DNS is invalid.
Cannot fix DNS.
Try 'ipconfig /renew' command.
