- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection drops 5-6 times per hour
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since 4/1 I've been having issues where my wifi connection will drop on multiple machines (OS X & Windows 10).
The wifi connection will disappear and when I attempt to rejoin the network my system will say that the network isn't found.
I can disable/enable my wifi on my laptops however I can't reconnect to them. I have to unplug the C3700 in order to reconnect. I have changed the router channels, reset the router via the dashboard as well as the button on the bottom of the device. My unit is 7-8 months old with the latest firmware.
I'm in need of assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection drops 5-6 times per hour
- Mark as New
- Bookmark
- Subscribe
- Permalink
No luck and no response yet however if I'm able to fix the issue or receive a response I will let you know.
Have you noticed your speed decrease as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everyone
What isp does everyone have? and does the internet just go out on the wifi or is it both the WIFI and LAN connections?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm with Comcast and as far I know it's just wifi and not the LAN connection.
What's odd is that I sometimes I can connect to the 5G network (or non-5G depending on which one I'm currently connected to) and it works after the original network kicks me off.
I've set my channels to ones where there is no other traffic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello DS404
You may want to contact Netgear support if this keeps happening may be a issue with the hardware of the wifi if all your devices are having this issue.
http://www.netgear.com/support/contact.aspx
DarrenM
