Orbi WiFi 7 RBE973
Reply
Disk Upgrade from 4X1TB to 4X3TB NV+ V2 4 Bay Not Working
pure_jax
I have followed the instructions to upgrade my Ready NAS NV+ V2 four bay from 4x1TB WD Green Power to 4X3TB Hitachi Deskstar 7K3000 HDS723030ALA640 however the volume is still reading 2.7TB
It is in an XRAID-2 Configuration and I replaced the drives one by one as instructed however it hasn't picked the extrat capacity and extended the volume.
Is there something I have missed? I have restarted the device multiple times.
The version of the firmware is RAIDiator 5.3.10 which i have tried to upgrade however this isnt working either.
I have also noticed my SMTP is not working for messages also.
Any advice appreciated.
Model: ReadyNASRND4000v2|ReadyNAS NV+ v2 Chassis only
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Disk Upgrade from 4X1TB to 4X3TB NV+ V2 4 Bay Not Working
> bay [...]
   You've posted this in a "Cable Modems & Routers" forum.  You might
get better answers sooner in some appropriate forum:
https://community.netgear.com/t5/ReadyNAS-Network-Storage/ct-p/readynas
   When you get there, you might also:
      Reveal which "the instructions" you claim to have followed.
      Explain what "this isn[']t working either" actually means.
   Free advice: "not working" (or similar) is not a useful problem
description.  It does not say what you did.  It does not say what
happened when you did it.  As usual, showing actual actions with their
actual results (error messages, ...) can be more helpful than vague
descriptions or interpretations.
Message 2 of 2
All Replies
antinode
Guru
> bay [...]
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 741 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
