- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does a CM600-1AZNAS (24*8) DOCSIS 3.0 Cable Modem, Certified for XFINITY work with other providers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am considering purchasing a CM600-1AZNAS (24*8) DOCSIS 3.0 Cable Modem, Certified for XFINITY. But I want to know if it works with other providers (such as comcast, time warner cable, charter, & more). I currently have xfinity but not sure if want to keep them.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is exactly same product with some possible minor packaging changes.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does a CM600-1AZNAS (24*8) DOCSIS 3.0 Cable Modem, Certified for XFINITY work with other provide
http://www.downloads.netgear.com/files/GDC/datasheet/en/CM600.pdf - Irregardless of of what the product sheet says, it's always a good idea to check with your potentially new provider to see if they support your modem first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for getting back to me.
The issue is that there are two types of CM600 on Amazon, One that is indicated to be certified by XFINITY by Comcast, Time Warner Cable, Cox, Charter & more: https://www.amazon.com/NETGEAR-download-960Mbps-Certified-XFINITY/dp/B01621M1S4/ref=sr_1_1?ie=UTF8&q...
and one that just says certified by XFINITY: https://www.amazon.com/Netgear-CM600-1AZNAS-download-960Mbps-Certified/dp/B06XGZBCKP/ref=sr_1_4?ie=U...
I wonder if the second one is compatible with other providers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
